I’ve been working on a new movement method for Offedit and Attach. This movement is 3d. It will draw axis bars on the elements so that you can move the object with a mouse (toggles on and off with right click) and also enable a setting to where the object will go where your mouse is so long as the left mouse button is active. I was just wondering if this would be something you want or not. Let me know your thoughts in the comments.
Progress
- Configuration (Done)
- Destroy Command (Done)
- Save Command (Done)
- Scale Command (Done)
- Select Command (Done)
- Collision Command (Done)
- Position Commands (Done)
- Rotation Commands (Done)
- Outlines [DX] (Done)
- Save Map Function (Done)
- Load Map Function (Done)
- MySQL Functions (Done)
- JSON to SQL Converter (Done & added SQL to JSON Converter)
- Create Object Function (Done)
- DX Utilities Download (Done)
- MySQL Server (Incomplete)
- User Panel [DX] (Incomplete)
- Admin Panel [DX] (Incomplete)
- Axis Lines [DX] (Incomplete)
- Axis Lines Functionality (Incomplete)
Note that the script has NOT been tested yet.
80% Complete done with script
Link To Script
I’ve cancelled progress on this script until I finish my dx library.
